2000 Ford Ranger Won't Shift, ABS Light
JBL456
I have a 2000 Ford Ranger with 115,000 miles. Just recently the ABS Light came on, the auto transmission fails to shift-stays in first gear, and the speedometer is not operating. What's the problem. Read the manual, it could be a speed sensor, electronic shift module, computer or tranny. Any ideas before I bring it in to the shop.
Jan 13, 2007 at 6:22 AM
INDYUKE
  • 416 POSTS
I would lean towards the speed sensor based on the fact that the speedometer isn't working. That also sounds like the easiest and least expensive thing to replace. Good luck!
Jan 13, 2007 at 7:33 AM
SERVICE WRITER
  • 9,123 POSTS
I agree with Indyuke , I have seen several rear speed sensors go bad on these.
Jan 13, 2007 at 7:38 AM
Suggested Repair
Check and replace the rear vehicle speed sensor first, since a failed sensor can disable the speedometer, keep the transmission in first gear, and turn on the ABS light.
Conversation Summary
The owner of a 2000 Ford Ranger with 115,000 miles reported an ABS light, an automatic transmission that stays in first gear, and a nonworking speedometer. Experts agreed the rear speed sensor is the most likely and least expensive cause to check first.
