VSA warning light and exclamation triangle light
173,000 MILES • 4 CYL • AUTOMATIC
KBERTELETTI
  • 5 POSTS
These lights come on once or twice a day now. If I see them, I stop car, turn off and restart, and the car resumes to drive normally. I just had starter, starter motor, and battery replaced and this issue has started since the repair.
Oct 11, 2019 at 8:12 AM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. You will need to have the ABS system scanned for trouble codes to get an idea as to what is going on. If this happened shortly after the battery replacement then you may need to have a zero point calibration done. But we do not know for sure until you post what trouble codes you have?
Oct 11, 2019 at 4:45 PM
