2000 Volvo V40 Misfire Shudder
Don't worry. Now U r OK. I had very similar Prob. When I inquired to Local dealer for price of coil he asked me which cylinder Nr. coil I want ? It gave me a click clue, the Company might have slightly different values set in different coils for each cylinders- lookwise all are same!
I swoped the coil on my own and it worked nice.
I can see that many mechanics don't know about this and when they clean the plugs, they swop the coils by mistake and hence the Misfire continues thereonwards.
Double check my assumption with dealer or some one knowledgeable before going further with me.
I would appreciate anybodu can confirm about different values set for different cylinder's coil - which I strongly believe.
Karpio
Suggested Repair
Treat the ignition coils as interchangeable and mark their positions before swapping them. Inspect and reseat the coil connectors and contacts, since a loose or poor connection can cause the misfire and may be corrected by moving the coil. If the cylinder 2 misfire remains after the swap, continue diagnosis rather than assuming the coil itself is faulty.
Conversation Summary
A 2000 Volvo V40 with about 97,000 miles developed a cylinder 2 misfire, shudder, and flashing check-engine light under hard acceleration, while running better at steady lower speeds. Mechanics checked the air filter, plugs, plug gap, and fuel pressure, replaced plugs, added fuel treatments, and swapped coils to isolate the fault; the problem later became intermittent. One owner reported success after swapping coils, and another after replacing cracked coils and cleaning the MAF sensor. The expert said all cylinder coils have the same value and can be interchanged, and that loose connections or bad contacts—not necessarily a failed coil—can be resolved by moving them.
