1998 Volvo V70 Rough Idle
JGERBER
I have a 1998 Volvo V70 GLT Wagon, with 104K miles.
Lately, particularly when the engine has been running a bit, the car idles roughly when I'm stopped at a light. It sometimes occurs when I'm in park, but not as often, and not as rough. The roughness is that it's not steady, it surges - so it will idles normally, then have a brief rough-surge, then idle relatively normally again. The closest I can come to describing it, is that it feels like it's about to stall, but then goes back to normal.
What do you think - just a tune-up, ore a death knell?
Apr 16, 2006 at 12:00 PM
LOSONE
  • 1,616 POSTS
It sounds like a vacuum leak or a bad idle air controller. Go to a shop with a smoke tester and pay his one hour fee to see the source of the vacuum leak. Good Luck
Apr 16, 2006 at 1:07 PM
Suggested Repair
Have a shop smoke-test the intake for a vacuum leak, and also check the idle air controller.
Conversation Summary
The owner of a 1998 Volvo V70 with about 104,000 miles reports a warm rough idle that surges and briefly feels like it may stall, mainly when stopped. An expert suggested a vacuum leak or a bad idle air controller and recommended a shop smoke test to locate any leak.
