1998 Volvo S70 Hesitant Acceleration
IFALLD0WNSTAIRS2
I have a 1998 Volvo GLT s70 with about 160,000 miles on it. When I go to accelerate hard it starts to skip and become hesitant to accelerate. Do you know what could possibly be the problem?
Aug 17, 2007 at 4:46 PM
  • 75,988 POSTS
[quote:574ee498ce="ifalld0wnstairs2@msn.com"]I have a 1998 Volvo GLT s70 with about 160,000 miles on it. When I go to accelerate hard it starts to skip and become hesitant to accelerate. Do you know what could possibly be the problem?[/quote:574ee498ce]
When was it last tune-up?
Aug 18, 2007 at 3:30 AM
IFALLD0WNSTAIRS2
I haven't taken it in recently for a tune-up. The last tune-up was a few months ago.
Aug 18, 2007 at 9:02 AM
  • 75,988 POSTS
[quote:1d87eb279a="ifalld0wnstairs2@msn.com"]I haven't taken it in recently for a tune-up. The last tune-up was a few months ago.[/quote:1d87eb279a]
Could be a fuel system issue-try having the fuel pressue check.
Could also be a problem with oxygen sensor/s, TPS / Airflow meter
Aug 18, 2007 at 10:01 AM
IFALLD0WNSTAIRS2
Okay. Thank you for your help.
Aug 18, 2007 at 10:28 AM
JMEAD6
Change you fuel filter and your O2 sensors. If no improvement.... The problem may lie in a clogged muffler or cat. Good luck. Got the same problem. Getting po422 code every once in a while. Going to start with the fuel filter and then the O2 sensors myself. I live in california and no seems to know the reason for remanufactored cats not being legal on california registered cars. And where to get a replacement. So I hope the 2 first things fix my problem.
Jan 1, 2009 at 12:29 AM
Suggested Repair
Check fuel pressure and the fuel filter. Also inspect the oxygen sensors, throttle position sensor, and airflow meter. If those checks do not help, consider a restricted muffler or catalytic converter.
Conversation Summary
The owner of a 1998 Volvo S70 GLT with about 160,000 miles reported skipping and hesitation during hard acceleration. A recent tune-up had been done a few months earlier. The expert suggested a fuel-system issue and recommended checking fuel pressure, along with the oxygen sensors, throttle position sensor, and airflow meter. Another user with a similar symptom suggested replacing the fuel filter and oxygen sensors first, then checking for a clogged muffler or catalytic converter if there is no improvement.
