1998 Volvo S70 Clunk After CV Axle
MOLECULE10000
i drive a 98 volvo s70, 5 cyinder engine, with 153,000 miles.
i had the passenger side cv axle replaced this morning in hopes of eliminating all of the problems i was told were associated with the broken shaft. these problems include clanking noises, alignment issues, brake problems, wobbling, and loss of control in any kind of precipitation... the car literally whips and swerves uncontrollably in rain, sleet, or snow. i had a wreck over a year ago that involved having the axle replaced and lots of work on the undercarriage. i haven't driven in rain since i had the cv replaced this morning (and i'm almost afraid to), but the brakes don't seem to be functioning any better than before and the clanking only got louder, and now there's even a pop when i turn the wheel to the right... is there anyone out there who can tell me what is going on?
Aug 24, 2007 at 6:21 AM
98RANGERXLT
  • 301 POSTS
I do not have a link but what you can do is go to autozone and they have this thing called Z net that shows you step by step on how to change it
Jul 9, 2007 at 1:18 PM
  • 75,988 POSTS
Reading it sounds like the axle wasn't installed properly, they didn't stab it right. Lift the car, jack it properly and look whether the axle is turning. Improper adjustment of wheel bearings- or something is loose.
Oct 10, 2007 at 11:22 AM
Suggested Repair
Recheck the passenger CV axle installation. Safely lift the car and confirm the axle is fully seated and turning with the wheel. Also inspect wheel-bearing adjustment and look for loose suspension or undercarriage parts that could cause the clunk, pop, and handling issues.
Conversation Summary
The owner of a 1998 Volvo S70 had the passenger CV axle replaced to stop clunking, alignment and brake concerns, wobbling, and loss of control in wet or slippery conditions after an earlier wreck. The brakes did not improve, the clunk became louder, and a pop appeared when turning right. One reply suggested using an AutoZone guide for axle replacement; another said the axle may not have been installed or seated correctly and recommended checking that it turns, along with wheel bearings and anything loose.
