1998 Volvo S70 Battery Drains
BOHES
I have a 1998 Volvo S70 GL. Small engine. If I fail to crank the car in 48 hours, the battery will die. I can jump the car, let it run for 20 min. and all is fine... unless I fail to crank it again in two days.
The car has a new batter and a new alternator.
It seems something is drawing energy all the time. I'm wondering if it's a computer problem or an electrical short of some kind.
Jul 31, 2007 at 9:11 AM
  • 75,988 POSTS
[quote:f67e798d64="bohes"]I have a 1998 Volvo S70 GL. Small engine. If I fail to crank the car in 48 hours, the battery will die. I can jump the car, let it run for 20 min. and all is fine... unless I fail to crank it again in two days.
It seems something is drawing energy all the time. I'm wondering if it's a computer problem or an electrical short of some kind.[/quote:f67e798d64]
Get a test lite remove positive battery cable put testlite alligator clip on the cable and pierce the battery positive post with the other end. If the test lite lits you have a short-now start removing fuses one at a time the one that turns the lite off is the problem circuit
Good Luck
Aug 18, 2007 at 3:37 AM
Suggested Repair
Check for a parasitic draw with a test light between the disconnected positive battery cable and the positive post. If the light stays on, remove fuses one at a time until it goes out to identify the circuit that is draining the battery.
Conversation Summary
A 1998 Volvo S70 GL battery dies if the car sits about 48 hours, even with a new battery and alternator. Jump-starting and running it briefly restores it until the next long sit. The expert advised using a test light on the positive battery connection and pulling fuses one at a time to find the circuit causing the constant draw.
