1999 Volvo S70 Ignition
MAHOFFMAN
Other Category problem
1999 Volvo S70 Engine Size unknown Front Wheel Drive Automatic 115000 miles
Sometimes, when I insert the key to start the car, the key just spins around. I can go 360 degrees, sometimes several times. So far, I have been able to get the key to "catch" and am able to start the car.
What is the problem and what is the solution? How expensive a situation is this? Thank you!
Dec 22, 2007 at 2:07 AM
BLACKOP555
  • 10,386 POSTS
sounds like the key cylinder may be broken and you will need a new one put in and other wear checked in it. the key cylinder shoudl only turn so far then stop not 360 and still keep goin!
Jul 17, 2008 at 8:28 AM
