2003 Volvo S40 Wheel Bearing and Control Arm Fix
CARMINE34
Can I change the front pass side wheel bearing myself or is it too involved? Too much to take apart?
Also need a rear control arm changed, can I change it myself?
Thanks,
CAC
Oct 25, 2007 at 2:43 AM
BLACKOP555
  • 10,386 POSTS
should be able to change the control arm.
for the bearing you will need to remove the wheel bearing assembly and have a shop press it out and put in a new one. unless you have a press.
Jul 15, 2008 at 3:47 PM
Suggested Repair
The rear control arm can be replaced DIY. For the front passenger wheel bearing, remove the wheel bearing assembly and have a shop press out the old bearing and install the new one unless you have a press.
Conversation Summary
The owner of a 2003 Volvo S40 asked whether the front passenger wheel bearing and a rear control arm can be replaced at home. The expert said the control arm should be doable DIY, while the bearing requires removing the assembly and pressing the bearing out and in at a shop unless a press is available.
