Volvo S40 Dark Oil After Oil Change
VOLVO
THOMASRON
I went to the dealer to have my oil changed but after the oil change the oil color on the dipstick was brown, not the usual honey or clear color I used to see on my previous vehicles' dipsticks following an oil change. I suspect the dealer did not change the oil because they either forgot in the midst of their busyness, or they simply forgot to do it. The dealer swears that the oil was changed, but I've never heard of a car's oil color being tan to brown in color following an oil change (assuming the filter was changed, as it was supposed to have been). Please let me know if I am being paranoid or if this does happen in Volvos or other cars. Thanks in advance!
Feb 14, 2007 at 11:43 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_note_12.jpg
Need the specifics to help answer. How often do you really change the oil? How does the filter look from the outside, you should be able to tell if it's clean and new from the outside. Some motors will tend to darken oil quicker due to hot spots from poor design. Oil that is not changed 3month/3000 miles will be more apt to give a dark color, sometimes immediatly. Some oils are darker than others. Oil may have not been fully drained.
Feb 14, 2007 at 11:56 AM
THOMASRON
This oil change was at 9,600 miles. My first oil change was at 4,000 miles, and the very same thing happened (dirty appearance of oil after the change). The first time, I didn't worry about it too much. This time I became much more concerned.
Thanks for the info about possible other causes; I now realize that it's much more plausible that this could just be the way things work with these types of engines. But then I wonder why did the dealer not tell me this when I made a big stink about it at the dealership. If he had told me that many Volvo S40s have the same problem, I would have understood and let it go. Thanks again though for the help.
Feb 14, 2007 at 12:15 PM
SERVICE WRITER
  • 9,123 POSTS
IMHO, change your oil every 3000 miles, oil is cheaper to replace than metal.
Feb 14, 2007 at 12:47 PM
Suggested Repair
Change the oil about every 3000 miles. Dark oil right after a change can come from leftover oil that was not fully drained, a darker oil, or an engine that darkens oil quickly. Confirm the filter looks new.
Conversation Summary
The owner saw brown oil on the dipstick immediately after a dealer oil change at 9600 miles and suspected the oil was not changed. The same thing happened at the first change around 4000 miles. The expert said some engines and oils darken quickly, residual oil may remain if it was not fully drained, and recommended changing oil every 3000 miles because oil is cheaper than engine wear.
