2001 Volvo S40 No Crank After Wash
BUBBYP
i have a 2001 volvo s40 with 57000 miles.my engine light came on and was a misfire on cyl 2. i changed the plugs then reset engine light. i then washed the engine compartment with a water hose. now it will not crank and i get a po602 control module programing error code. i also noticed an arrow flashing on my dash. what should i do to fix this
Sep 9, 2007 at 7:09 AM
2CARPRO JACK
  • 11,533 POSTS
Its a little late now, but you shouldnt wash the engine with a garden hose.Unplug and dry out every connector you can find under the hood, with the battery disconnected
Oct 16, 2007 at 4:24 AM
Suggested Repair
Disconnect the battery, then unplug and thoroughly dry every electrical connector under the hood. Do not wash the engine bay with a garden hose.
Conversation Summary
The owner of a 2001 Volvo S40 had a cylinder 2 misfire, replaced the spark plugs, and reset the check-engine light. After washing the engine compartment with a hose, the car would not crank, a P0602 control-module programming code appeared, and a dash arrow flashed. The expert advised disconnecting the battery and drying all underhood connectors.
