2002 Volvo S40 car takes forever to start.
EDROC23
  • 2002 VOLVO S40
Engine Performance problem
2002 Volvo S40 4 cyl Two Wheel Drive Automatic 113K miles
The car does not start right away. You have to have to hold the key on start for 5 to 10 seconds before the car finally turns on
Saturday, January 23rd, 2010 AT 10:50 AM
JIS001
  • 3,411 POSTS
Your fuel pressure regulator could be leaking. Next time before starting, remove the vacuum hose from the pressure regulator at the intake side. If there is fuel present then that is what's causing your hard start. Replace it and you will be fine after that.
Saturday, January 30th, 2010 AT 3:08 PM
