The FRONT right turn signal light is not blinking. Assuming it is simply that I need a new amber bulb. How do I change it?
Must I removed the entire lens housing the bulb; there does not appear to be any other access. And if so, how do I go about remove the housing?
Also, where is the flasher relay located. How do I identify it, just in case that's the problem. My right rear turn signal seems to be blinking fine, in case that's of interest in assessing the problem overall.
I'd appreciate any help you might be able to provide.
Jun 10, 2008 at 1:54 AM
