1995 Volvo 850
MYTI
  • 1995 VOLVO 850
Smells problem
1995 Volvo 850 V12 Two Wheel Drive Automatic
I am not getting gas to the inject rail, so I checked the lines and filters, they were fine so I went to the fuel pump cover in trunk, took it off and found a conecter plug undone so I pluged it back in, then turned it over and it cranked for few minuets then it quit again, so I pushed the gas valve on the rail and gas flowed to a stop, now nothing, What do ya"ll think.
Tuesday, August 26th, 2008 AT 4:13 PM
KHLOW2008
  • 41,814 POSTS
Hi myti,
If power is being suppplied to the fuel pump and no pressure, the pump is bad. Knocking/vibrating the pump might make it work temporarily.
If there is no power supply, you need to check the fuel pump relay.
Friday, August 29th, 2008 AT 6:58 AM
