1990 Volvo 740 Starting
CRAIGG
  • 1990 VOLVO 740
  • 4 CYL
  • 210,000 MILES
Hi I have a 1990 volvo 740 turbo I replaced the battery and the alternator a few days ago, question is when its cold out say 30 or colder it wont start you have to jump it cause it cranks so long it kills the battery but when you get it started and in warmer weather it runs fine just wont start in the cold any ideas
Friday, January 16th, 2009 AT 10:26 PM
KHLOW2008
  • 41,814 POSTS
Hi craigg,
Thank you for the donation.
Hope the following helps.
HARD TO START - COLD ENGINE
Ensure spark plugs fire strong Blue-White spark.
Check distributor.
Ensure fuel pressure is correct.
Check ignition timing.
Check throttle switch and connector.
Check engine compression.
Saturday, January 17th, 2009 AT 9:56 AM
