1990 Volvo 740 starting problem
CHELUZO
  • 1990 VOLVO 740
1990 Volvo 740 4 cyl Two Wheel Drive Automatic
Suddenly my car refused to start.
Battery charged, gas in the tank, engine will crank(rev) but would not run. Thanks
Monday, February 2nd, 2009 AT 10:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
You will first need to check to ensure all spark plugs are receiving a bright blue healthy spark. Also check to make sure fuel pressure is at correct PSI. Let me know what you get and I will follow up.
Thanks for using 2CarPros. Com!
Tuesday, February 3rd, 2009 AT 12:29 AM
DENVBRONCOS
  • 20 POSTS
Also to ad to bluelightnin6, another common issue is the crank sensor that goes into the top of transmission casing straight down from valve cover by fire wall. Easy to replace one bolt. And connector at top of firewall next to wiring harness.
Sunday, June 16th, 2019 AT 4:55 AM
