1989 Volvo 740 no spark
1989 VOLVO 740
215,000 MILES • 4 CYL • 2WD • MANUAL
JCHAPIN
My volvo, while driving down the road, just stopped.
I do most of the wortk on the car and this has me stumped. There is no spark to the plugs. The coil checks out fine and there is voltage to the coil. I don't know what to check next. Please send any advice you might have.
Mar 15, 2008 at 5:53 PM
BMRFIXIT
  • 19,053 POSTS
on the rear of engine in the tranny bell housing you have a sensor
I think Volvo calls it ignition impulse sensor (crank sensor )
check /replace it
check also the relay under hood by the right shock
good luck
Mar 15, 2008 at 7:01 PM
JCHAPIN
[quote:ddfd620697="jchapin"]Electrical problem
1989 Volvo 740 4 cyl Two Wheel Drive Manual 215000 miles
I do most of the wortk on the car and this has me stumped. There is no spark to the plugs. The coil checks out fine and there is voltage to the coil. I don't know what to check next. Please send any advice you might have.[/quote:ddfd620697]
It turned it as was simple as replacing the cap and roter. A little oil had tainted the inside of the cap and fouled the connection. Thanks for the suggestion though.
Mar 22, 2008 at 9:10 AM
