2003 Volkswagen TDI Replace Alternator
2003 VOLKSWAGEN JETTA TDI
280,000 MILES • 4 CYL • FWD • MANUAL
DIESELLOVER
  • 13 POSTS
The alternator is tightly situated in the VW Jetta TDi - and was a bit difficult to remove. However, it is even more challenging to re-install the reman alternator. I have used hours to try to "slide" it into the bracket, but to no avail. What is the key to getting the alternator into its bracket and lined up again? Thanks!
Tom
Dec 21, 2009 at 10:29 AM
DR LOOT
  • 2,311 POSTS
there is a pushing on the alternator at the bottom that you will need to push back, a pair of pliers will usually do the job.
Due to the high level of no responses to post questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 19, 2010 at 1:37 AM
