2002 Volkswagen Passat Serpentine Belt Change
2002 VOLKSWAGEN PASSAT
92,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOLORESLEE
Is the labor to change a $16 belt worth the $240 quoted?
Jul 2, 2009 at 9:01 AM
STEVEW84
  • CAR REPAIR CONTRIBUTOR
  • 673 POSTS
If it is a 1.8T, probably. If it is a 2.0 then no. For a 1.8 you most likely have to take the bumper off and some other stuff off. For the 2.0 then you should be able to get to it, but I think there are 2 belts for that car. If there is or isn't then it is still easier than doing a 1.8. Get a manual.
Jul 16, 2009 at 7:43 AM
