2001 Volkswagen Passat Timing Belt, Bent Valves, Locked Crankshaft
PANTH80
  • 2001 VOLKSWAGEN PASSAT
  • 6 CYL
  • FWD
  • MANUAL
  • 107,000 MILES
I have a 2001 VW Passat 2.8 V6. My friend said that he could repair timing belts and so I let him fix mine. But when we tried to start it up it made a pinging sound and then cut off. He read through the manual and found out that the timing belt wasn't set right. I suspect we might have some broken valves, however we can't get the crankshaft to move at all. Is it possible that the valves got caught up in the piston and thats the reason for the crankshaft not turning?
Saturday, April 5th, 2008 AT 7:12 PM
MASTERTECHTIM
  • 4,750 POSTS
Absolutely. Was the belt broken or were you replacing it for maintainance reasons?
Saturday, April 5th, 2008 AT 8:14 PM
PANTH80
We were replacing the water pump, but since we had to remove the timing belt I thought it to be a good idea to replace that as well. Is this something that would be better to replace the valves or am I looking at buying a whole new engine?
Saturday, April 5th, 2008 AT 9:10 PM
MASTERTECHTIM
  • 4,750 POSTS
Most of the time you can just replace the valves and you are ok. There is a slight chance of a broken piston, you will have to remove the head to check.
Sunday, April 6th, 2008 AT 5:50 PM
2003_PASSAT_GLX
Had broken in collision timing belt and right side belt tooth wheel. Since car wasn't running I tested valves by rotating manualy just that side firs and finding no crank sounds did same on other side. Everything sounds OK. Now, I have to replace that tooth wheel and timing belt, but can't find picturial guide. Any links? TIA
Monday, April 21st, 2008 AT 4:20 PM
UNDER_THE_RADAR
My (now former) daily-driver, '96 Audi A4 quattro, 2.8, 12-valve, 140k mi, just slipped some teeth on the timing belt resulting in cylinder/valve contact - looking at $4,500 for all the things that are wrong, including a fuel sender sensor for about $500 of that (quote from a "high-end" euro shop) - I thought the car was worth that BEFORE all of this mess - can't see spending that kind of cash
most non-audi places tell me they don't have the specialized tools for an Audi, and turn me away.
I'm actually preparing to embark on head gasket replacement and several other things on my '94 Lincoln Mk8 - HERE'S THE QUESTION - am I insane for thinking I should keep the Audi and take a stab at it myself?
Maybe I'll get my hands on a shop manual and see what they say about the tools required.
Thanks, take care
Thursday, June 19th, 2008 AT 4:56 PM
