2000 Volkswagen Jetta No Start
2000 VOLKSWAGEN
GFORCE
My 2000 Jetta 2.0 with 125000 miles will not start. I changed the fuel filter, fule regulator and spark plugs and still all it does is crank over. How can you determine if it is getting any spark? also would the fuel injectors have any thing to do with this? I am getting frustrated because it was running great and then the next day it won't start....
Please help
Oct 9, 2007 at 12:19 AM
  • 75,988 POSTS
Disconnect a plug wire or 2 ground it to the engine while cranking it over-do you have spark? If so check for fuel-crank engine over while listening to the injector/s is it clicking and do you smell fuel vapor in the throttle body?
Oct 9, 2007 at 5:01 AM
Suggested Repair
Ground one or two spark plug wires to the engine while cranking to confirm spark. If spark is present, crank the engine and listen for injector clicking, and check for fuel vapor at the throttle body.
Conversation Summary
A 2000 Volkswagen Jetta 2.0 with 125,000 miles cranks but will not start after running normally the day before. The owner already replaced the fuel filter, fuel regulator, and spark plugs. The expert advised checking spark by grounding a plug wire while cranking, then checking fuel by listening for injector clicking and smelling for fuel vapor at the throttle body.
