1998 Other Volkswagen Models Car stalls
1998 VOLKSWAGEN
186,000 MILES • 4 CYL • FWD • MANUAL
MLAKOMY
I have a 1998 Volkswagon Cabrio. It stalls after I've been driving it for about a half-hour. It has happened three times. The first two times, after I waited awhile (30 minutes?) the car started again and was drivable. I changed the airfilter and cleaned the throttle. I took the car to inspection (yesterday) and it passed. Today the car stalled again. (I'm waiting to see if it will work in an hour). It tends to stall when I am slowing down (turns, stop and go traffic) but not actually stopped. The battery is new (6 months) and I've cleaned the connections. I have plenty of gas and added an engine cleaner when I cleaned the throttle. Any suggestions? Thanks.
Jun 24, 2008 at 1:46 AM
KHLOW2008
  • 41,814 POSTS
Hi mlakomy,
You passed inspection so I take it that no check engine light was showing.
I can think of 2 possible causes
1. Faulty ignition coil, heats up and it stalls.
2. Faulty ignition switch or wire connections, heats up and power supply is cut off due to high resistance.
Jul 5, 2008 at 6:06 PM
