There are many things that can stop the car from running we need isolate the system that is failing, it will be related to the ignition system or fuel injection system. It could be a crank sensor, cam sensor, pcm relay, ignition module, pcm, fuel pump etc, is the check engine light on? If so you can scan the pcm for trouble codes and go from there. Please let me know what you come up with.
SPONSORED LINKS
Wednesday, November 7th, 2007 AT 7:29 AM
