1999 Jetta 2.0 - Engine stalls when stopping
1999 VOLKSWAGEN
DMACIAS
  • 9 POSTS
I have a 1999 Jetta New body Style 2.0 L AEG and with the A/C on the Car stalls when slowing down or at low idle. WIth the A/C off it will not stall. I currently have a P1128 code. The car idle seems to be going up and down slightly. What can I check for to fix this problem?
Thanks
Nov 5, 2007 at 6:38 AM
MERLIN2021
  • 17,250 POSTS
Long term fuel trim bank 1 too lean= Too much air! You have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak!
Nov 5, 2007 at 6:58 AM
