1998 Volkswagen Jetta Idle Stall
1998 VOLKSWAGEN
DRUNKKTURTLE
I have a 1998 volkswagen jetta. The car basically only stalls out when
it is idling and then I turn the wheel, although once in a blue moon it
will actually while im driving down the road. The coil, computer, burnt
valves, distributor have all been replaced with the presumption that
this may fix the problem. Also an electrical relay was even added in as
well. i basically spent over a grand on the car so far to try and fix
this and i'm all out of ideas.
Apr 3, 2007 at 5:08 AM
  • 55,758 POSTS
First check fuel pressure, then try cleaning the throttle body, and idle air control valve. Also check your air intake boot leading to the MAF sensor for cracks in the boot. let me know please.
Apr 3, 2007 at 5:28 AM
Suggested Repair
Check fuel pressure, clean the throttle body and idle air control valve, and inspect the air intake boot to the MAF sensor for cracks.
Conversation Summary
A 1998 Volkswagen Jetta stalls mainly at idle when the steering wheel is turned, and occasionally while driving. The coil, computer, valves, distributor, and an added electrical relay have already been replaced without fixing it. The expert recommends checking fuel pressure, cleaning the throttle body and idle air control valve, and inspecting the intake boot to the MAF for cracks.
