Hey,
For the past month, my 1995 Volkswagen Jetta TD (110000 miles) speedometer and the other gauge that measures how fast the motor is turning have been going on and off. When they're off, they sometimes vibrate when the car is on. The electronic gauge that measures how many miles you do always works fine. So I suspect its a connection problem inside the instrument cluster only relating to the speedometer and the other gauge. I've thought about opening it and checking the connection of the wires but I don't know where to start. I've got the equipment to solder electronic wires so any tips on what the problem is or which wire it might be inside the instrument cluster would be greatly appreciated. I know that there’s a ton of wires in there but any help would be appreciated.
Thanks
Thanks
Jan 13, 2007 at 5:17 AM
