2003 Volkswagen Jetta Loosing Coolant
2003 VOLKSWAGEN JETTA
75,000 MILES • 4 CYL • 2WD • MANUAL
DCCOLVIN
I have a 2003 VW Jetta 1.8T, it drives perfect. However, the coolant doesn't return to the reservoir, sometimes when I release the reservoir cap it will start to rise. Sometimes it doesn't. No smoke or sweet smell from the exhaust. Could it be that the reserevoir cap is not sealing tight?
Jul 5, 2008 at 3:49 PM
KHLOW2008
  • 41,814 POSTS
Hi dccolvin,
No, it is not the reservoir cap.
The system is under pressure and when you release the cap, pressure will escape thus the rise in the level.
The coolant is recycling when the engine is started so you would not see much difference in the level.
If the coolant keeps disappearing, you need to check for leakages. Check hose joints.
Jul 5, 2008 at 5:15 PM
