First of all, tell me what kind of oil you've been running in your engine? I want you to remove the Hoes from the cold side of the turbo and start it up and tell me if it is spinning, have you checked your air cleaner to make sure it's not restricted? The only other thing you could be is the wast gate, it is vacuum activated, and it may be bad, or you have a broken vacuum line to it, or maybe no vacuum at all, that will cause it to stay open all the time, and not build up any turbo boost.
SPONSORED LINKS
Sunday, March 29th, 2009 AT 11:14 AM
