2000 Volkswagen Jetta car turns over but will not start
SHANNONJONES
MEMBER
2000 VOLKSWAGEN JETTA
Engine Mechanical problem
2000 Volkswagen Jetta 6 cyl Manual 136200 miles
I had to change the battery now the car turns over but will not start
Tuesday, December 22nd, 2009 AT 2:55 PM
DOCFIXIT
MECHANIC
Hi
Check the battery fuse panel see if something got fried during change.
Let me know
Thnaks for donate
SPONSORED LINKS
Tuesday, December 20th, 2016 AT 11:07 AM
SHANNONJONES
MEMBER
There are 3 fuses in the box on top of the battery that look to be ok. Am I in the right place and if I am should I replace just to make sure I dont have a a muti- meter with me
DOCFIXIT
MECHANIC
Check to see if any of the fuseable links are burnt the little metal strips.
SHANNONJONES
MEMBER
No they look like normal wear
DOCFIXIT
MECHANIC
Need to see what is not happening spark or fuel. So pull plug wire hold next to block. Crank spark? If yes then spray some carb cleaner in air intake crank run for sec?
Let me know
SPONSORED LINKS
SHANNONJONES
MEMBER
I have to wait on my to get home so I will get back to you in the am
