2000 Volkswagen Jetta car will not start
DORO69
  • 2000 VOLKSWAGEN JETTA
Engine Mechanical problem
2000 Volkswagen Jetta 4 cyl Two Wheel Drive Manual
hello, we have a 2000 jetta and out of the blue, the car dos not start. The starter is okay. What else can we check out. Gaz is in the tank too. Lol
thanks
Sunday, June 27th, 2010 AT 1:38 PM
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard i
Tuesday, December 20th, 2016 AT 11:19 AM
DORO69
Hello, thanks for you fast answer, I will check it out today and let you know.
Anyway, the engine is turning on, all the lights come on etc, it just wont start. It makes a sound like it will start, but nothing will happen.
Related Engine Not Running Content
