1997 Volkswagen Jetta Doesn't want to run in the rain
128,000 MILES • 4 CYL • FWD • MANUAL
SKOPP2002
If I am driving in the rain the car will start to stutter like it wants to die but will usually stay running. If it has been sitting in the rain, like over night, it won't start at all until it dries out.
Oct 30, 2009 at 4:16 AM
AJVANDYKE
  • 36 POSTS
Strange problem would like to help is there anything else you could tell me about the car/problem. Does it have an aftermarket "cold air intake" by chance? Thats about the only thing I could think of that would cause that off hand
Dec 20, 2016 at 3:11 AM
SKOPP2002
I don't think it has any after markets but I'm not sure.
STEVEW84
  • 673 POSTS
Is the check engine light on? If so, what are the codes?
ILOVEMYVWJETTA
Dont even waste ur time or money. all you need is a new tune up trust i have had the same excat problem mine even shut off on me . all you need is New spark plug, New spark plug wires, cap and rotors thats what come with a complete new tune up good luck and let me know
STEVEW84
  • 673 POSTS
so, you like to just throw parts at cars and not do any testing?
KAREEM2283
Check the spark wire set, rotor, rotor cap, and ignition coil for cracks. Quick alternative is to spray them with WD40 and it will resist the water if there is any crack.
