Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volkswagen
Jetta
Engine
Symptoms
Not Running
car wont start but turn over
1997 VOLKSWAGEN JETTA
1,946,980 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ANTHONY BARRON
MEMBER
Gas not coming out front,is there an fuel cut off switch on 97 Jetta 2.0 if so located where
Jan 29, 2016 at 9:21 PM
Experienced Mechanic
Is the fuel pump running at all? you should heat the pump cycle with the ignition on, need to know if the pump is actually working first.
Dec 20, 2016 at 3:11 AM
ANTHONY BARRON
MEMBER
Yes its working ,wondering if its in the Iniction do to the fact,I had to replace it also by pass my alarm
ANTHONY BARRON
MEMBER
Thankyou for all your help,car is running and just need to find out why oil light is beeping(flashing)
Is this the engine oil pressure, low oil level or engine service light, check the hand book to identify which warning is activated
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
