1994 Volkswagen Jetta Check Engine Light
KARIEK
  • 1994 VOLKSWAGEN JETTA
Computer problem
1994 Volkswagen Jetta 4 cyl Automatic 148000 miles
Check engine light stays on, checked the codes using the fuse/jumper (OBDI) and no codes appear and the light goes off; however, as soon as you remove the jumper the light comes back on. How can you figure out what to fix if there are no codes and the car runs great? I can't pass smog as long as the check engine light stays on.
Wednesday, September 1st, 2010 AT 8:58 PM
  • 31,937 POSTS
Before any conclusion can be drawn, you should get a scanner hooked up, flash codes are not always reliable.
Mark (mhpautos)
Thursday, September 2nd, 2010 AT 2:01 AM
KARIEK
Unfortunately, I have been to 2-VW Dealers, 1-Electrical Specialist and 2-Mechanics//Maint Facilities and no one can get any codes from their OBD 1 Scanner/Code Reader, they even try the OBD II for fun, that's why we also tried it the old fashioned way.
Thursday, September 2nd, 2010 AT 7:50 PM
  • 31,937 POSTS
Hi there,
What you need to do first is test the fault gathering capabilities of the ECU, to do this you can induce a known fault, unplug the air flow meter and start the car, the ECU should set a code for this, if not there is a fault with in the ECU.
Mark (mhpautos)
Thursday, September 2nd, 2010 AT 8:07 PM
KARIEK
We will try this tomorrow and I will let you know the outcome.
Saturday, September 4th, 2010 AT 8:06 PM
  • 31,937 POSTS
OK, let me know how you get on.
Mark (mhpautos)
Sunday, September 5th, 2010 AT 2:57 AM
Related Check Engine Light Content
