HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volkswagen
Beetle
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1965 Volkswagen Beetle gas in oil
ZAPAD
MEMBER
1965 VOLKSWAGEN BEETLE
Engine Mechanical problem
1965 Volkswagen Beetle 4 cyl Two Wheel Drive Manual? Miles
I have gas in my oil what would cause this? I replaced the fuel pump and that didn't help.
Thank you
Monday, April 7th, 2008 AT 3:20 PM
MERLIN2021
MECHANIC
Lets say the fuel pump's OK, is this bug hard to start? If you have been cranking it a lot, it may be washing part the rings.
SPONSORED LINKS
Monday, April 7th, 2008 AT 3:27 PM
ZAPAD
MEMBER
I opened the crankcase and tried to start engine, raw gas drained out of it. I think it might be the rings. Thanks
Monday, April 7th, 2008 AT 10:47 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
Changed Fuel Pump Car Won't Start
I Changed The Fuel Pump In My Wife's Car And It Turned Over The First Time We Tried But Hasn't Since.
Asked by
shnickly
1998
VOLKSWAGEN BEETLE
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
2000 Volkswagen Beetle Fuel Pump Knocks Loudly
My Vw Bug Is A 2000 1.8l Turbo. It Has About 87,000 On It. I Just Replaced The Fuel Pump With An Oe Replacement And It Is Making The Same...
Asked by
02marc
2000
VOLKSWAGEN BEETLE
2002 Volkswagen Beetle Fuel Pump Replacement
After Getting A Very High Estimate On The Labor To Install A Fuel Pump In A 2002 Vw Beetle. And After Doing Mechanic Work For 25 Years I Don...
Asked by
vic7974
2002
VOLKSWAGEN BEETLE
2002 Volkswagen Beetle My Veh Will Start But Shut-off
My Vehicle Will Start But Then @ Times It Will Shut Itself Off, Sometimes Taking 2-3 Attempts For The Veh To Stay Running. I Have Three...
Asked by
kathleen stringer
1 ANSWER
2002
VOLKSWAGEN BEETLE
Fuel Pump Fuse
I Have A 1979 Vw Convertible Beetle, Fuel Injected. Where Is The Fuel Pump Fuse Other Than At The Fuel Pump Relay? I Think It May Be...
Asked by
charles kelley
1979
VOLKSWAGEN BEETLE
VIEW MORE
SPONSORED LINKS
How to fix an engine that wont start
Engine Not Starting
Fuel Pump Pressure Test
Online car repair manuals
