Fuel pump Fuse
CHARLES KELLEY
I have a 1979 VW Convertible Beetle, Fuel injected.
Where is the fuel pump fuse other than at the fuel pump relay?
I think it may be on the fuel pump under the gas tank at the r front wheel?
chase
Jun 24, 2009 at 7:28 AM
MIKE H R
  • 3,094 POSTS
the power for the fuel pump comes from the ignition switch then goes to a double relay located behind the rear seat. it has power when the switch is turned on.
Jun 27, 2009 at 6:57 AM
VOORHOUTER1
for a supper beetle Fuel injection don't forget the extra wire that is attached to the negative pin of the battery with out it the fuel pump wont work
Aug 18, 2018 at 2:14 AM
JKBROWN2
where does that extra wire come from?
Feb 23, 2023 at 11:29 PM
MARK DEANGELIS
Where does that wire go to?
Nov 8, 2024 at 8:05 PM
  • 55,691 POSTS
You will need a manual for this car, our information does not go this far back, sorry,
Nov 9, 2024 at 3:26 AM
