Can you hear the fuel pump run for about two seconds once you first turn the key to run, before you turn the key to start?
If not, check the fuel pump relay fuse.
It is the "fuel" fuse in the engine room fuse box, located under the hood, left side.
Also, there is a "eng" fuse for the other half of that fuel pump relay and it is located in the relay block, which is behind the right end of the dash.
Jan 12, 2018 at 11:41 PM
