no start starts then wont start after shut down
178,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
BARRY760
Changed fuel pump codes po7 00 po 431 po128 airbag light on
Jun 26, 2014 at 12:40 AM
HMAC300
  • 48,601 POSTS
your 128 code sis themostat malfunction and 431 is a converter problem or ecm problem so best a pro look at this also he can scan for the abs problem either a sensor or something else. there is not p0700 code listed. A pro has to look at everything under the scan to see if O2 sensors are working ok just to be sure check fuel pump pressure with a gauge should be 47-49 psi with vacuum line disconnected. Also try resetting your anti theft if no manual check online.
Jun 26, 2014 at 1:09 AM
BARRY760
code po 700 is a trans code ithought it may be connected
Jun 26, 2014 at 1:29 AM
BARRY760
ialso chaned the coolant temp sensor
Jun 26, 2014 at 1:31 AM
HMAC300
  • 48,601 POSTS
I know it's a trans code but for kia the don't list that one. and the 431 like I said can be an ecm problem but they have to use a scanner and see if O2 readings are normal and do a few other things that autoparts scanners can't do.
Jun 26, 2014 at 1:33 AM
