1997 Vauxhall Vectra losing power then stops
MAGBEN
  • 1997 VAUXHALL VECTRA
  • 6 CYL
  • MANUAL
  • 96,000 MILES
Hi hope you can help, Engine management light staying on, took to garage, they fixed couple of things, then said car needed new exhaust manifold gasket, also camshaft sensor not working, have replaced cambelt and manifold gasket, took it out today, was going fine on motorway then light came on again and car judders, then starts to loose power and then comes to a stop, turn car off for a couple of minutes, then start up again and it runs fine for a while, then goes again, I do not have much money and cannot afford to take back to garage, my son can do most things on my car, but do not know what is wtong with it now after all the new things we have put on there, please please help before oi scrap and have to catch buses.
Friday, March 6th, 2009 AT 6:28 PM
DAVE H
  • 13,384 POSTS
You need to replace the actual "camshaft sensor" if that is what the diagnostic computer told the tech was the fault !! .. The fault sounds to me like it is the CKP (crankshaft position sensor) this controls spark output for the plugs and a common fault on this vehicle !! I do not have any diagrams as the vauxhall range was not released in the USA .. your local library should be able to supply a manual for the vehicle or your local autoparts store !! hope this helps .. let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_23.png
Friday, March 6th, 2009 AT 6:42 PM
MAGBEN
Hi, thank you we will do this tomorrow and let you know, thank you for your quick reply
Friday, March 6th, 2009 AT 6:50 PM
