Vauxhall Vectra Manifold Leak Judder
VAUXHALL
HARLAN
i have a vauxhall vectra t reg 2.0 cdi and i was wondering when the manifold gasket packs in does this cause the car to judder and loss performance i also want informaton on how to get the brake pad warning of the car computer becuse they have just been replaced thanks
Aug 3, 2007 at 5:29 AM
DAVE H
  • 13,383 POSTS
the brake pad warning light should go out automatically on replacement .. check the connectors on the new pads are connected correctly .. exhaust manifold leak could cause driveability issues
Feb 27, 2009 at 2:49 PM
Suggested Repair
An exhaust manifold leak can cause judder and loss of performance, so check the manifold gasket. The brake pad warning should go out automatically after pad replacement; verify the wear-sensor connectors on the new pads are connected correctly.
Conversation Summary
The owner of a Vauxhall Vectra T-reg 2.0 CDI asked whether a failed manifold gasket can cause judder and loss of performance, and how to clear the brake pad warning after new pads. The expert said an exhaust manifold leak can cause driveability issues, and that the brake warning should extinguish automatically if the new pad connectors are fitted correctly.
