1997 Vauxhall Vectra Stalls on Clutch
VAUXHALL
CALV
I have a 1997 Vauxhall Vectra 1.8 GLS and for a little while now it has been cutting out when i have pushed the clutch down, mainly when i've slowed right down to change down gear. I had a new idle motor put in a year ago, and i thought it might be the cat converter but my car passed it's mot today, emissions were fine and everything. They did notice that the engine light was on but said this was'nt a fail.
A friend told me today that it could be something as simple as putting some cleaner through to get rid of dirt from the petrol tank if i've been running the car on low petrol levels. So i'm confused and thats why i'm here.
Thanks in advance for any help.
Calv.
Aug 7, 2006 at 8:21 AM
MIKEYBDMAN
  • 623 POSTS
[quote:a257e91d00="Calv"]Hi,
Calv.[/quote:a257e91d00]
Most likely if your engine light is on, it has a code that will direct you to the problem with your car. I would take the car to a parts store lie Autozone and have the code read. Then fix the system that is faulting, and your problem should be gone.
Aug 7, 2006 at 8:53 AM
CALV
Great, thanks for that.
Calv.
Aug 7, 2006 at 9:14 AM
Suggested Repair
Have the check-engine light code read at a parts store, then repair the system indicated by the fault code.
Conversation Summary
The owner of a 1997 Vauxhall Vectra 1.8 GLS reports the engine cutting out when the clutch is pressed, mainly while slowing to downshift. A new idle motor was fitted a year earlier, the car passed its MOT with fine emissions, and the engine light is on. A friend suggested fuel-system cleaner, but the expert advised reading the stored code and repairing the faulting system.
