2003 Vauxhall Vectra Cruise Control
VAUXHALL
JINGOJOEZ
Vaxhual Vectra, 2003 model, 39000
I did not use cruise control for about 2 days and when I tried to use it, it would not work at all. I pressed the button several times and the switch does not even show on deshboard. I have tried it from 40mph to 80mph but nothing. No any message from the computer about anything. I dont know what to do next? I hope you can help me out.
Oct 9, 2007 at 5:28 AM
DAVE H
  • 13,383 POSTS
check the C/C fuse in the underdash fuse box !
Mar 12, 2009 at 7:33 AM
JONO_OZ
[quote:decc5e8ba4="Dave H"]check the C/C fuse in the underdash fuse box ![/quote:decc5e8ba4]
Which one is that ?
The fuses are not labelled clearly.
May 5, 2009 at 1:11 AM
JONO_OZ
I just got my car back from the mechanic last week and the cruise control has stopped working as well.
I took a look at the fuse box in the drivers footwell. When you remove the plastic cover, it has a whole lot of symbols on the inside of it and the corresponding fuse number.
There are symbols everywhere for things like horn, windows, mirror, fans, indicators, but I don't see the exact symbol for the cruise control light - a round clock-like dial.
May 5, 2009 at 1:25 AM
Suggested Repair
Check the cruise control fuse in the underdash fuse box in the driver's footwell, using the cover diagram to identify the correct fuse.
Conversation Summary
The owner of a 2003 Vauxhall Vectra reports that cruise control stopped working after not being used for about two days. The switch does not illuminate on the dashboard at any speed, and there are no computer messages. An expert advised checking the cruise control fuse in the underdash fuse box. The owner could not identify that fuse from the cover symbols and noted the problem also appeared after a recent mechanic visit.
