2002 Vauxhall Omega Turns over but fails to start..........
2002 VAUXHALL OMEGA
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBMETAXA
Had a problem for the last week or so, when I go to start, turn the key, engine turns over but will not start, tried with both keys and still no joy (not immobilizer!), leave car for 20/30 min and starts with the flick of the key!!!!!
Very annoying when you are late for work.
For the first few times when you turn the key, I waited for the lights to go out (Engine managment etc) then tried to start, thought I was tring to start to quick!! but after last night the engine managment light stays on, until I finally got it started after leaving it for 20/30 mins!!!! when it went out. Now stays on when all others go out, until the engine stars.
Thanks
Rob Reed
Jan 30, 2009 at 6:26 PM
Let start by getting the computer scanned for OBD2 code/s and comeback with it this is where we start
Jan 30, 2009 at 8:51 PM
ROBMETAXA
Well guys done the pedal trick, and got a code 0335, which I understand is a fault with the crank sensor!!
Thanks
Rob
Feb 2, 2009 at 2:00 AM
