2005 Vauxhall Astra WONT START
PERKY
  • 2005 VAUXHALL ASTRA
2005 Vauxhall Astra 4 cyl Front Wheel Drive Manual
TRIED USUAL SUSPECTS. HAD A SLIGHT BANG. DOES THIS CAR HAVE AN INERTIA CUT OFF SWITCH AND IF SO WHERE IS IT PLEASE. WONT EVEN TURN OVER JUST A CLICKING SOUND FROM FUSE BOX. THANX LYNN
Friday, February 6th, 2009 AT 12:40 PM
DAVE H
  • 13,384 POSTS
Vauxhalls are not fitted with a fuel cut off switch. You need to check the wiring from battery to starter motor.
Saturday, February 7th, 2009 AT 10:12 PM
PERKY
Thank you very much for your reply for answering inertia switch question. Have tried what you said fault lies in fuse box, moisture getting in caused corrosion on terminals. Need to go to vauxhall "stealers " to replace.
Sunday, February 8th, 2009 AT 5:37 AM
DAVE H
  • 13,384 POSTS
You could try checking at a good recycle/scrap yard that deals with accident damaged vehicles ! Just a thought
Sunday, February 8th, 2009 AT 6:09 AM
