Car will not start dies after being jumped
105,000 MILES • 1.7L • MANUAL
DES THOMAS
My car was not starting on the weekend. Tried jump cables as well and would not start. Thought it may be a problem with the alternator. Had a friend come and look at it today and started it using jump leads and the car started. Turned the car off after a few minutes and tried starting it again but it would not. Goes back to same problem had on the weekend. Do you think this is definitely an alternator problem or could be something different?
Oct 10, 2016 at 3:48 AM
DES THOMAS
Battery is fine only had a new one two months ago.
Oct 10, 2016 at 4:51 AM
CJ MEDEVAC
  • 11,000 POSTS
I have seen them installed right off of the shelf and be bad.
Reason for them there warranty's, 'round here, two months would be a free replacement! (PROVIDING IT IS THE BATTERY)
Change the battery and run it to the auto store for testing (Which should include the alternator, still on the vehicle, too!)
or
You can check it yourself, here is a link!
Return with good news!
The Medic
Oct 10, 2016 at 8:52 AM
