Intermittent issue of shutting off after engine has warmed
136 MILES
LAURA WAIKEL SETTLES
Van starts to cut out after it has warmed up a bit. Not continuously but very often that i can't drive it very far.
Jun 15, 2021 at 2:22 AM
More than likely this is a spark or fuel issue. So let's start with fuel because that is the easier one to confirm with an issue like this.
Here is a guide that will help with fuel pressure:
Basically I would just tape the gauge to the windshield and then drive it until it acts up. Then you can monitor what the fuel pressure does.
If the pressure remains steady then we most likely have a spark issue.
We could still have an issue with an air flow sensor or some other sensor but if we have no codes then we most likely have a base engine issue.
Lastly here are a couple guides that will help with this issue and checking codes if you have not done that yet.
https://www.2carpros.com/articles/engine-stalls
Please let us know what you find with all this and we can go from there. Thanks
Jun 16, 2021 at 12:47 PM
