1997 Oldsmobile Silhouette Car Stalling
125,000 MILES • 6 CYL • FWD • AUTOMATIC
TSWIFT
The problem started while I was driving. The car started fine but then with no warning the car stalled. I pulled it over and it restarted fine. I continued to drive home then it stalled again, once again restarting fine seconds later. Brought it home and tested the battery which was reading low. So we went out and changed the battery. But when I went to go and warm up the car this afternoon it did it again. And the alternator tested fine. The van starts up fine but then dies after a few minutes. What could be causing it to do this?
Feb 23, 2009 at 2:12 AM
  • 75,988 POSTS
Check the fuel pressure and comeback with the readings we start here.
Feb 23, 2009 at 2:15 AM
TSWIFT
Just wanted to let you know that the reason my car wasn't starting was because I had a bad fuse in the fuse block. It was a hack job fix of someone trying to fix the van before I purchased it.
May 22, 2009 at 9:37 AM
