Crank no start issue?
149,880 MILES • V8 • 2WD • AUTOMATIC
DTCLARK
My van has run perfectly fine for the past few days with the only minor hiccup being the power sometimes cutting when I try to start it but then working fine when I try again after. I assume that problem is unrelated. I've been driving up and down an extremely dusty and bumpy road for a few weeks and camping in the woods. When I woke up this morning, I attempted to start it and the starter keeps trying but there's no turnover. The oil pressure rises when I continue to try, nothing electrical cuts out and I've even tried jumping it, but it feels like it's not getting any fuel to me and my friend.
I don't have any idea where the fuel injectors or similar components are on my van, so I haven't been able to check. Being in the woods leaves me at a disadvantage for performing diagnostic or getting beneath the van. I also have no testing equipment. If possible, I would appreciate some form of ghetto fix for now as I'm still waiting on my first paycheck before I can get parts or fluids, having my vehicle being able to start just once more would allow me to at least relocate closer to work and get it properly fixed.
May 21, 2023 at 2:17 PM
  • 110,248 POSTS
By chance, can you get starting fluid? If you can, see if it starts and then stalls. If it does, then we know it is fuel related. If there is no change, chances are there is no spark to the plugs. In most cases, which is the result of a faulty crankshaft position sensor.
Here is a link that explains how to check for spark, but it does require some basic tooling. If you have no access to anything, I'm not sure what to say because a crank no start condition can be caused by different things.
Here is the link for checking spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know if you could try either of those two tests.
joe
May 21, 2023 at 2:42 PM
