1998 Chevy Express 1998 will not start
JNOLL
  • 1998 CHEVROLET EXPRESS
  • V8
  • 150,000 MILES
My 1998 Express will not start. I have replace the ignition module, coil, cm sensor, rotor button, distributor cap, and spark plugs. After replace the the ignition module coil cm sensor cap and rotor button the van start but had engine ligt on. Ran for a week then died. It at the shop now and all component have been changed again and still will not start. Fuel pressure is 60 psi. Scanner does not show any problems. Engine cranks over good. The plug have yello spark. I need help any ideas appreciated
Friday, January 30th, 2009 AT 9:31 PM
Yellow spark means the ignition system is weak, Do you have injection pulses at the injector/s? Try starter fluid thru the throttle body and see what happens
Friday, January 30th, 2009 AT 11:14 PM
JNOLL
I did spray starter fluid in the throttle body. The engine did not start or even to appear to desial. I would think even with starter fluid having a low flash point I would have gotten the engine to desial. I am completely stumped. I am installing a new computer to see if this does anyting.
Tuesday, February 3rd, 2009 AT 7:56 PM
