Did this start right after power washing the engine? If it is coming from the front of the engine, check to see if any of the belt-driven accessories are loose or causing the sound. Also, if you remove the serpentine belt and start the engine briefly, is the sound gone?
Let me know. Only run it for a few seconds if you remove the belt. Only run it long enough to see if the sound is gone.
Also, if you can record it and upload it for me to hear, I may recognize the noise. Let me know the engine size as well.
Jul 29, 2023 at 3:40 PM
