Undoing the crank shaft bolt
16 MILES • 1.6L • 4 CYL • 2WD • MANUAL
IAN SUNDERLAND
should the crank shaft bolt be clockwise or anti clockwise to undo it?
Sep 15, 2019 at 1:10 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I need the correct year and engine size. The Escort wasn't introduced until 1981.
Sep 15, 2019 at 10:52 AM
IAN SUNDERLAND
Hi Joe.
Thanks for your reply. I am actually not sure of the engine size! The engine is actually in a boat!! All I know is that it is a 1974/5 engine fitted to the forerunner of the escort. It produces 80bhp
Cheers
Ian
Sep 17, 2019 at 11:36 AM
  • 110,248 POSTS
Welcome back:
Without knowing the specifics, that's a tough one to answer. What I suggest is this. Take and put a socket on the bolt with a good breaker bar. Smack it with a dead blow hammer in the counter clockwise directions a few good times. It should break loose. If it refuses to, then it could be a reverse thread, but to be honest, that would be an odd one.
Let me know if it comes loose for you.
Sep 17, 2019 at 12:41 PM
IAN SUNDERLAND
Hi Joe.
Thanks, job done.
Ian
Sep 19, 2019 at 7:28 AM
  • 110,248 POSTS
Welcome back:
Glad to hear it. Was it a standard thread?
Sep 19, 2019 at 11:46 AM
